If you look at servicebox you can see that there are two different subframes for the 208.
When UR made the braces they probably used a non GTi model with another subframe.
When I tried to install the front brace the bolt patern of the brace did not line up with the bolts of the GTi subframe.
Fitting all the other braces was no problem at all and they all fit like a glove.
