Résultats de 41 à 50 sur 52
  1. #41
    116 Post(s)
    OK Merci :)
    la température d'huile est bien disponible sur nos 208 gti mais pour l'instant que avec la valise peugeot, faut juste maintenant savoir comment recupere l'info avec un elm327
Nom : bsi2010 208gti.PNG
Affichages : 1149
Taille : 164.7 Ko
Nom : bsi2010 208 gti.PNG
Affichages : 1089
Taille : 168.0 Ko
Nom : bsi2010 information moteur 208 gti.PNG
Affichages : 1073
Taille : 145.9 Ko
  2. #42
    Italie
    6 Post(s)
    Pseudo-déterrage: vous avez du nouveau sur cette fameuse sonde de température d'huile?
    Ou sur comment l'utiliser pour obtenir la température d'huile?
    The 208 GTi BPS (208ch euro6) does not have the oil temperature sensor.
    There are only the oil pressure sensor and oil level sensor.
    The oil temperature is only calculated by engine ECU and sent to the BSI through the CAN bus (inside the data packet with address 0x488 for the MEVD17.4.4 ECU)
    According to the MED17.4.2 Funktionsrahmen also this ecu and probably the MEVD17.4.2 has the oil temperature transmitted in the data package with address 0x488
  3. #43
    116 Post(s)
    Citation Envoyé par mfc Voir le message
    the oil level sensor is actually the oil temperature sensor that is used by the calculator to measure the level thanks to a mathematical formula
  4. #44
    Italie
    6 Post(s)
    You are right in saying that the oil level sensor is also the oil temperature sensor; according to the official PSA documentation for the EP6FDTX engine, the oil level sensor (P/N:9806246080) has 3 pins:
    1: oil level
    2: oil temperature
    3: ground
    but, unfortunately, the pin 2 is not connected to anything...
  5. #45
    116 Post(s)
    1: oil level
    2: oil temperature
    3: ground
    it's a resistance probe
Nom : sonde d'huile 208 gti.PNG
Affichages : 1119
Taille : 160.9 Ko
  6. #46
    Italie
    6 Post(s)
    yes is a resistance probe, but you note that:
    "The engine oil level sensor is only active when the vehicle contact is switched on and is deactivated when the engine is started."
    the resistance variation caused by the temperature is much larger on the "temperature" side than on the "level" side of the probe.
    Images jointes Images jointes
  7. #47
    Italie
    6 Post(s)
    thi is the electrical connection of the probe to the ecu MEVD17.4.4
  8. #48
    116 Post(s)
    with diagbox we can display an oil temperature value. I guess the calculator will retrieve this information on the oil level sensor to display this value.
  9. #49
    Italie
    6 Post(s)
    for completeness of information.
    the message with 0x488 address is sent 10 times per second and is composed by 8 byte of data with the following meaning (at least for the MEVD17.4.4 ECU):
    Byte 1: water temperature: you need to add +40°C to get the real temperature in °C
    Byte 2: volumetric fuel consumption: you need to multiply the value by 80 to get the volume in mm^3
    Byte 3: requested engine idle: you need to multiply the value by 8 to get the RPM
    Byte 6: oil temperature: you need to add +40°C to get the real temperature in °C
    Byte 8: boost air temperature: you need to add +40°C to get the real temperature in °C
  10. #50
    116 Post(s)
    il y a peut être des chance d'avoir des info de diagbox sur torque, j'ai mis les info dans le sujet diagbox telemetry https://www.208gti.fr/showthread.php...elemetry/page3
