The 208 GTi BPS (208ch euro6) does not have the oil temperature sensor.
There are only the oil pressure sensor and oil level sensor.
The oil temperature is only calculated by engine ECU and sent to the BSI through the CAN bus (inside the data packet with address 0x488 for the MEVD17.4.4 ECU)
According to the MED17.4.2 Funktionsrahmen also this ecu and probably the MEVD17.4.2 has the oil temperature transmitted in the data package with address 0x488
