Page 3 sur 8 PremièrePremière 12345 ... DernièreDernière
Résultats de 21 à 30 sur 75
    Italie
    6 Post(s)
    probably every ECU revision use different addresses and PID codes: the ecu on my car is the MEVD17.4.4.
    If you have still access to the diagobox tool, you can easily discover the address+custom PID for every parameter:
    you must connect the diagobox tool and the ELM327 dongle together to the OBD port, put the ELM327 in "listening mode" and, on the diagbox, select to measure only one parameter at a time (using the dedicated menu)
    Let me know if you need other infos about that...
  2. #22
    Italie
    6 Post(s)
    does not work for my ecu .
    i found an application on android runs with the chip elm327 and offers functions that approaches the diagbox without the telemetry
    https://play.google.com/store/apps/d....faplite&hl=fr
    Fichier joint 15491
    I didn't know this app: I will test it, analyzing the data traffic on the CAN bus, to see if the app uses custom PSA PIDs or the classical OBDII PIDs.
  3. #23
    Citation Envoyé par mfc Voir le message
    how to connect the box elm327 and the diagbox together on the same socket obd
  4. #24
    Italie
    6 Post(s)
    the easiest way is to buy a OBDII "Y" or "splitter" cable with 1 male and 2 females connectors
  5. #25
    I did not know that it exists, otherwise can you explain to me a little more the setting to do on the diagbox with the elm327
    Nom : 61vMK-0U+qL._AC_SX679_.jpg
Affichages : 728
Taille : 32.2 Ko
  6. #26
    Italie
    6 Post(s)
    as I had already written in a previous post, to enable the listening mode:
    AT H1
    AT D1
    AT CAF0
    to listen all the messages from the 6xx addresses:
    AT MR 06
    to listen all the messages from the 4xx addresses:
    AT MR 04
    to listen a specific message address (e.i. 0x488):
    AT CF 488
    AT CM FFF
    on the diagbox tools, there is a menu like "personalized parameter reading" in which you can select which value to read continuously
    if you need it, tomorrow, I can send you a screen shot of this menu...
  7. #27
    AT H1
    AT D1
    AT CAF0
    AT MR 06
    AT MR 04
    AT CF 488
    AT CM FFF
    I received my cable today, to connect the diagbox and the elm327. I made custom measurements with the diagbox and monitor the bus can with elm327 on the engine calculator. Diagbox uses the 6A8 header for engine calculator
    regime moteur / engine rpm
    6A8 5 04 21 C0 80 01
    température calculateur/ calculator temperature
    6A8 5 04 21 CB 80 01
    température air extérieur / outside air temperature
    6A8 5 04 21 C2 80 01
    température eau / water temperature
    température huile / oil temperature
    position pédale accélérateur / accelerator pedal position
    6A8 5 04 21 CA 80 01
  8. #28
    on décortique la ligne de commande custom init
    at sp 6 pour la sélection du protocole iso 15765-4 can (11 bit id, 500 kbaud)
    at sh 6a8 pour sélection de l'en-tête
    at fc sd 30 00 00 flow control set data
    at fc sm 1 flow control set mode
    at cra 688 set the can rx addr
    81 pour se connecter au calculateur moteur
    10c0
    après essai sa fonctionne pas, mais j'ai peut être trouves le problème qui viendrait de la commande at fc sd 30 00 00. Sur ma 208 avec le diagbox il envoi la commande 6a8 30 00 05, je vais remplacer le 30 00 00 par 30 00 05
    nouvelle custom init
    atsp6\natsh6a8\natfcsh6a8\natfcsd300005\natfcsm1\n atcra688\n81\n10c0
  9. #29
    1- on lance le scan de tous les calculateur sur le diagbox
    Nom : scan tous les calculateur.PNG
Affichages : 843
Taille : 51.9 Ko
    2- on se connecte au calculateur MEVD17.4.2
    Nom : connecter au calculateur moteur.PNG
Affichages : 807
Taille : 52.6 Ko
    3- on lance une mesure personnaliser
    Nom : demande mesure personaliser.PNG
Affichages : 866
Taille : 53.4 Ko
    on retrouve bien les ligne
    6A8 01 81
    6A8 30 00 05
    6A8 04 21 C0 80 01
    avec les en-tête 6A8 et 688
  10. #30
    Super travail, j'ai hâte de voir la suite !
